Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
some 18 wh truck MPG tips can apply to pickups
Old Apr 15, 2006 | 10:35 AM
HankL's Avatar
HankL
Default some 18 wh truck MPG tips can apply to pickups
http://www.landlinemag.com/Archives/...tmoremiles.htm
sample quote:
"Slice through the air
Aerodynamics play a big part in fuel economy. A truck’s coefficient of drag is the sum of many factors. One rule-of-thumb often mentioned at TMC is that all things being equal – of course they never are – a fully aerodynamic truck will do roughly 1 mpg better than a classic tractor.
TMC Recommended Practice RP 1111, Relationships Between Truck Components and Fuel Economy, indicates that shortening the gap between tractor and trailer to 25 inches can save from a half of a percent to 5 percent, depending on where it was set.
Air deflectors can save up to 6 percent, while a full roof fairing can save up to 15 percent. Other aerodynamic savings include: cab extenders, up to 2 percent; contoured air dam front bumpers, up to 3 percent; tractor side skirts, up to 3 percent.
RP 1111 also states that switching from lug-type drive tires to rib-type can improve mpg 2 percent to 4 percent. Worn tires, with less mass to flex, can be 5 percent to 10 percent more fuel efficient than new ones, so expect a drop when you replace tires. "
Even Peterbilt
famous for its brick-like 'Macho' old fashioned rigs
is offering full aero truck designs
along with tweaks on the old body style
http://www.peterbilt.com/index_new_m...5&archivedate=
much more MPG improvement info
