Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Maint. ?......plugs,ATF. etc
Old Jun 2, 2004 | 07:33 PM
DakaDan's Avatar
DakaDan
Default Maint. ?......plugs,ATF. etc
I have some general questions for you guys & gals. Spark plugs/wires, swap them @ 30k. Dealer recommended it. Book says 30k for plugs, 60k for wires. ATF fluid, dealer says every 12k miles. Talking with one of the Dodge techician, he says 60k is sufficant, as long as no heavy towing. Says the ATF +4 is a syn blend, anti-foaming bla bla bla. I understand that the dealer will recommend everything underneath the sun, I just want to get a general idea what do to. I am @ 29k miles, so sometime this summer I would like to do some maint.
Or let me ask you, what should I do for 30k mile maint. Dealer quoted me ~$600 for maint. [sm=smiley35.gif]
Includes.
Oil Change
Inspect front suspension, fluids, brakes, lights.
Perform battery service, throttle body service, engine tune-up, fuel injection flush.
Tranny service
check cooling system
Replace fuel filter.
Most of this stuff I can do myself, just wanted to get some opionons
DakaDan
Old Jun 2, 2004 | 08:15 PM
slvrmagnum's Avatar
slvrmagnum
Default RE: Maint. ?......plugs,ATF. etc
Do it yourself and with the Trans fluid, 60k is about right, but make sure you use what is already in there. I have heard about trans problems if you switch the fluid.
Old Jun 3, 2004 | 11:28 AM
sreitz's Avatar
sreitz
What tools do you need to replace a fuel filter. I thought that was kinda complicated?
Old Jun 3, 2004 | 09:25 PM
glock45's Avatar
glock45
sreitz -
I have an 02 1500 4.7 short bed and here is what the manual states in regards to the fuel filter.
"FUEL FILTER/PRESSURE
REGULATOR
DESCRIPTION
A combination fuel filter and fuel pressure regulator
is used on all engines. It is located on the
top of the fuel pump module. A separate frame
mounted fuel filter is not used with any engine.
Both fuel filters (at bottom of fuel pump module
and within fuel pressure regulator) are designed for
extended service. They do not require normal scheduled
maintenance. Filters should only be replaced if
a diagnostic procedure indicates to do so."
Old Jun 4, 2004 | 01:54 PM
B12Teuton's Avatar
B12Teuton
I would change the plugs, oil, tranny fluid, air filter, coolant and brake fluid. Check the pads for wear.
Everything else should be fine.
Personally, I would change the axle's gear oil to synthetic too. (*other if you have a limited slip diff)
