Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Transponder???
Old Nov 18, 2003 | 05:06 PM
Ram 1500's Avatar
Ram 1500
Default Transponder???
Hi</P>
I have a 2002 model Ram 1500 and I have installed a remote starter on it and I get a PATSK-300/350 passlock 1&amp;2transponder from Canada, so I am wondering if I can use it on my Dodge???</P>
PS. I live in Norway and nobody here knows anything about remote starters here...</P>
Thanks</P>
Old Nov 18, 2003 | 06:08 PM
ViperGTS's Avatar
ViperGTS
Most remote starters only work with fuel-injected automatic transmissions. It should work if it is...
Old Nov 18, 2003 | 06:51 PM
DODGE Germany's Avatar
DODGE Germany
Hi,out there.Matt is right, but if you own a manuel it works, too.You can punkd the security lock coming from the P-gear clearance of an automatic if you bind it with the signalcable of your handbrake-lights to the dash. The only thing is that you must be sure on the Neutral-gear in your manuel by used your handbreak (feetbreak!!)first. Greetings from Germany to the Neighbourhood.Mikel, (Dodge Germany)</P>
