Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Tranny acting wierd on freeway
Old Aug 11, 2004 | 01:47 PM
  #21
steve05ram360's Avatar
steve05ram360
Default RE: Tranny acting wierd on freeway
pull your tps connector & check to make sure the connector is not corroded, clean it well & try it again. Has the tranny ever been pulled? could be you have a bad connection somewhere around the tranny...
has anyone heard of a tranny speed sensor causing this problem?
Kevro7, i'd do a search on the tranny speed sensor & see what the symptoms were before they (poster) replaced it, not sure if this could be your problem but it's worth looking into
Old Aug 11, 2004 | 10:29 PM
  #22
kevro7's Avatar
kevro7
as far i know, the tranny has never been pulled. i've thought about the speed sensor but thats as far as i've made it. checked for bad connections and no problems there that i could see. thanks for all the help! i'll look into it a little more
thanks
kevin
Old Aug 12, 2004 | 05:24 PM
  #23
kevro7's Avatar
kevro7
was wondering if i could manually control the lockup of the TC? I know that the diesels can do this with just some wire and a toggle switch. wasn't sure if this could be done on a gas vehicle. all the components required to do it are there.
Old Aug 12, 2004 | 05:44 PM
  #24
steve05ram360
there is a way to lockup the converter but I've never done it. I'm tempted though, in the mountains it would be nice to just unlock the TC instead of downshifting. Seems that the TC get's locked pretty quickly.
One other thing to consider is the IAC motor may need to be cleaned. Clean it & all the contacts for the wiring. What about the A/C kicking on & off? the idle is usually raised when it's on, but I wouldn't think it would be affected when cruising...
Old Aug 12, 2004 | 10:40 PM
  #25
kevro7's Avatar
kevro7
as for the A/C, its been a very rare very cool summer here in Kansas, so i haven't even turned the A/C on all summer. i'll clean the IAC and all of it components and if that doesn't work i'm gonna stick my neck out and try the manual lockup switch. i'll let you know how it goes if it gets that far. thanks steve00ram360!
Old Aug 16, 2004 | 12:57 AM
  #26
kevro7's Avatar
kevro7
could a leak in the upper plenum gasket cause a vacuum leak that would in turn make the lockup portion of the TC work erracticly?
Old Aug 16, 2004 | 09:30 PM
  #27
DakaDan's Avatar
DakaDan
Well while I had my truck in for the fuel pump, I told the tech about my problem. He checked the codes and said the my TPS was "flacuating" (spelling). Dealer swaped TPS and havent had a problem since this weekend. FYI I drove over 200 miles home back from wisconsin dells. I'll keep you guys updated.
DakaDan
