Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Dual Exhaust
Old Jul 15, 2004 | 05:57 PM
ditchdoc's Avatar
ditchdoc
Default RE: Dual Exhaust
Ok this guy will cut my cat but his said he will kill my truck do I have ot have it or will the computer go crazy?Also should I turn both out to one side or one each side?
Thanks
Larry
Old Jul 15, 2004 | 06:03 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
taking the CATs out will make it MUCH llouder,,,
Old Jul 15, 2004 | 06:34 PM
moparturd's Avatar
moparturd
It will confuse the computer. there are some fake o2 sensors you can get that fool the computer into thinking it's seeing the data/resistance/whatever from the o2 sensor.
Old Jul 15, 2004 | 07:00 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
my basis for comparison with the CATs removed is a dakota RT, he has installed the O2 black box. the only problem he ran into, there is a black box with a blinking red light,and when coming through customs from canada, they freaked out about it.
Old Jul 15, 2004 | 10:02 PM
ditchdoc's Avatar
ditchdoc
I will look into the 02 sensor.
Old Jul 15, 2004 | 11:51 PM
trumpetguy27's Avatar
trumpetguy27
Just curious...
Isnt removing the Cat illegal in most states? Im pretty sure it is here... and I can only imagine it would make passing an emissions test near impossible. Just curious how guys that remove them handle this part of things.
Old Jul 16, 2004 | 12:20 AM
moparturd's Avatar
moparturd
It is here as well. Just pull the thing off and knock the guts out and return it to the system.
Old Jul 16, 2004 | 01:05 AM
Sean99TJ's Avatar
Sean99TJ
additionally the PCM adjusts fuel-air mixture based on what the 02 sensors input is......if you fake the input....to rich?, to lean? How will you know? You gonna pull your plugs weekly to see if they are gray or brown?
Old Jul 17, 2004 | 01:47 PM
crcarch's Avatar
crcarch
The Cat-back exhaust's sound awesome and give proven power gains with them in. Why would you want to go "old school" and bypass for what may equal no or little power gain and a headache with the CPU?
Maybe I'm a victim of manufacturer's hype, but I though they'd pretty much made back pressure a non-issue now with Cat's. All the hi-po stuff is designed to perform with them in place without having to go to great lengths to fool the computer. Plus if you make it illegal, you have to replace it before you sell it.
Old Jul 17, 2004 | 11:41 PM
SOPMOD's Avatar
SOPMOD
I just replaced my entire system.
Got Pacesetter headers ($149) and sent them to JETHOT and had them nickle coated, New High flow Cat ($139), DynoMax 3" in 3" out and Three inch pipe all the way to the rear ($159). (All parts came from Summit Racing) JET HOT Header coating is awsome and well worth the 170 bucks.
I have a 360/5.9 in my Ram 1500, now it sounds as bad as it looks.....at least I think so........
Later
