Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Ram 1500 carwash recommendations
Old Jul 20, 2004 | 01:05 PM
  #21
steve05ram360's Avatar
steve05ram360
Default RE: Ram 1500 carwash recommendations
I would go here http://bimmer.roadfly.org/bmw/forums/detailing/ and see what these guys do. I just use soap & water and dry it with a chamois. Some of those bimmer guys are so **** about their cars it's rediculous, but it is an excellent source of info.
Old Jul 21, 2004 | 04:47 PM
  #22
CanadianRAM's Avatar
CanadianRAM
Love my Mr. Clean kit to! Still hand wash though, just use the filtered water for the rinse.
Old Jul 23, 2004 | 04:09 PM
  #23
TSR6's Avatar
TSR6
You really don't want to use a chamois. If there is any dirt left on the truck while you are drying it, the chamois will trap it between itself and the paint surface.
Old Jul 23, 2004 | 05:06 PM
  #24
cw_cdz's Avatar
cw_cdz
Check out this post by Mikegonzo from a while back, excellent response!
Amanda: This should be in an FAQ or something, or maybe it is I have missed it =]
https://dodgeforum.com/tm.asp?m=15084
Old Jul 25, 2004 | 01:07 PM
  #25
Shamrock's Avatar
Shamrock
ORIGINAL: cw_cdz
That's a pretty good write up, if you follow that you won't have much trouble.
I disagree with the part about the chamois and water blade though. I feel the chamois is safer than the water blade, because if you get any grit stuck in the blade, it will leave some very nasty scratches behind.
The part about using the hose without the end on and using a blower is really good. I always do both, the blower helps to get any water out of crevises so it won't leak out and leave streaks after you think you've got it dry. It also cuts down on drying time.
Finally, even though your truck is new, it can still pick up some rail dust while being delivered. You might want to check into using a clay bar on it. Do not use Mother's clay bar though, it is defective and will leave streaks and junk on the finish. They might have fixed the problem by now, but since they burnt me the last time, I won't be using them again.
Old Jul 25, 2004 | 01:34 PM
  #26
nick449's Avatar
nick449
Thanks for all of the suggestions regarding handwashing...looks like I'll have to grow some longer arms.
Took delivery of the red Ram SRT 10 two days ago and just love it. Super torque like my 2001 Z06 Corvette... quiet with great handling. I'm getting triple takes as I drive by people...only 4 SRT 10's in Wisconsin at this time.
Thanks Dodge!!
Nick449
Old Aug 6, 2004 | 01:58 PM
  #27
mloughrige's Avatar
mloughrige
I have a 03 ram hemi that has never seen a car wash (except the quarter car wash), with fiberglass cover with the spoiler i don't need the scratches, it's a little more work buy it's worth it. mine is silver and the fly's love to (poop) on it and the only to get it off is to use was any ideas ?
Old Aug 6, 2004 | 02:00 PM
  #28
mloughrige's Avatar
mloughrige
that's wax not was sorry
Old Aug 6, 2004 | 10:35 PM
  #29
gpzjack's Avatar
gpzjack
Only thing that scares me about car washes is the ones with high pressure water can blast the grease out of some fittings on your suspension.
Old Aug 7, 2004 | 12:04 AM
  #30
dustyloins's Avatar
dustyloins
Hall of Fame Member
Around here we have ones with "triggers" on the wands, if you want low pressure, you release the trigger....
