Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
air cond.psi too high
Old Jul 19, 2004 | 09:00 PM
herbie707's Avatar
herbie707
Default air cond.psi too high
i would like some help on an ac
i have two trucks doing the same thing they are both 2000 dodge ram desials
ac compreser is showing 50psi on low side and starts at 200psi on the high side but the hi side keeps going up to about 425 when the overload switch turns off the compreser
could the drier or oraves tube cause this or what might it
any help would be great
Old Jul 20, 2004 | 01:59 AM
nicks360's Avatar
nicks360
Default RE: air cond.psi too high
Almost sounds like you may have too much refrigerant in your system.
Old Jul 20, 2004 | 10:39 AM
herbie707's Avatar
herbie707
i know that is the why it looks but it calls for 2.00 pounds and i only put in 1.25 pounds
Old Jul 20, 2004 | 02:24 PM
Traction Issuez's Avatar
Traction Issuez
Sounds like your compressor's workin overtime. Might want to get that looked at.
issuez
Old Jul 21, 2004 | 03:52 AM
HemiMan02's Avatar
HemiMan02
well i just finished an automotive air conditioning class so i know some stuff on this subject. first if you have a fixed orifice tube you dont have a receiver driver so you need to figure out which you have first. my dodge has an orifice tube but its a 96 and not diesel. if it has an orifice tube heres how you can figure it out. find the high side line and this should be hot after the condensor outlet.... then as soon as the line changes from hot to cold thats where your restriction is... it should change temps at the fixed OT...if it changes before then your restriction may be in your condensor. if you have a receiver drier the temperature should change at the thermostatic expansion valve which is after the R/D. hope you find this helpful.
Old Jul 21, 2004 | 06:30 PM
herbie707's Avatar
herbie707
i now have an ofice tube and a new drier hope to have them in tonight
had to get a kit to cut out the ofice tube it is in the high side line behind the battery
they want 50.00 to replace the line i got a kit to cut it out for 20.00
thanks for all your help
Old Jul 22, 2004 | 05:49 AM
94ram4x4 5.9's Avatar
94ram4x4 5.9
start with releasing some freon out of you system...worked for my truck!
