A/C troubles
having troubles with the A/C in the ram
when the A/C is on full blast and on the recirculate setting all of a sudden it will just start shooting out of the vents by the windshield then like 20 seconds later it will go back to normal sometimes it wont do that but its starting to do that alot more often
any idears thanx
any idears thanx
I know most rams, if not all, have vacuum assisted venting, which means all the little baffles and ducts move with the assistance of vacuum pressure from the engine. chase down all the vacuum lines leading into the cab to the airbox area and check them out. a Vacuum failure could do what you are experiencing.
