Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
APPS/TPS sensor
Old Dec 18, 2003 | 06:35 PM
diesel bay's Avatar
diesel bay
Default APPS/TPS sensor
<FONT face="Arial, Helvetica, sans-serif">I Have a code on my truck for the APPS sensor Which used to be called TPS sensor.But any Way i Have a 1999 dodge Diesel 24V 4x4 standard and recently my trucks gas peddle would not work for a second then kick back in then the engine light would *** on then after starting it about 3 times the light would go out,but the code will still be there when you use a code reader.I have erased the code once before.but its happened again.My question is if any one has had this happen to them with there diesel and is there a way to test the apps sensor or if maybe there is a way to clean or fix it.A new APPS sensor is about $700CAD.Like i sad this is not a steady problem its just had two hick-ups.If any one knows how to test it(the shop manual doesn't say how)or fix it or had a problem like this I would appreciate the Help.Thank you.<IMG src=smileys/smiley4.gif border="0"></FONT>
