Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Computer resetting issue
Old Jan 22, 2007 | 01:43 AM
drockstar's Avatar
drockstar
Default Computer resetting issue
I have noticed something with my transmission shifting problem. If I re-set the computer by disconnecting the battery for 30 minutes, the transmission shifts fine. However, when I turn the ignition off and crank it back up, it doesn't shift into 3rd or 4th gear. This thing is driving me nuts. Has anyone experienced this? By the way, I dropped the pan today, no metal particles on the magnet. I refilled it with ATF-4 and a can of TransTune, but I still have the same problem.
If it is a computer problem, where is the most likely culprit located?
Old Jan 22, 2007 | 03:30 PM
drockstar's Avatar
drockstar
Default RE: Computer resetting issue
anyone?
Old Jan 23, 2007 | 12:41 AM
drockstar's Avatar
drockstar
Well, I got it figured out. I had it scanned at Autozone and it came up with a P0753 error code. Well, it was the speed sensor module that screws into the side of the transfer case. It cost me $30 bucks to replace it. Autozone had one in stock.
If any of you come across the problem, it is a module with a white plastic 1" hex bolt. A 2-wire female plug hooks to it. It is located on the transfer case on the drivers side. Changing it out only takes about 5 minutes. When you remove the old one, be careful, about a 1/2 cup of transmission fluid may come out which may be hot.
[IMG]local://upfiles/53710/9CB5D2B0DF764094B9090E35E8083BC0.jpg[/IMG]
[IMG]local://upfiles/53710/61812CBC779C47A0A28576F046FF9EC6.jpg[/IMG]
Old Jan 24, 2007 | 12:21 PM
GhostRider3387's Avatar
GhostRider3387
Thanks for the info. Had the same thing happen on a concord the wife used to own.
