Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Extra turn Lights
Old Feb 24, 2007 | 12:25 PM
solarwarp's Avatar
solarwarp
Default Extra turn Lights
I have an 07 2500HD 4x4 Quad Cab Diesel and want to run some extra lights.
Where is the easiest place to tap in to get right and left "turn signal only" and will adding extra led's overload the system?
TIA
Old Feb 25, 2007 | 12:49 PM
solarwarp's Avatar
solarwarp
Default RE: Extra turn Lights
I did find this chart which is for the 3500 Chassis Cab, but I suspect the 2500HD is similar; which indicates that the front turn signal circuit is not designed to handle any additional lighting load.
http://www.dodge.com/bodybuilder/200.../dr/dclcpu.pdf
I guess I need to add a Hoppy 46365 or similar to isolate the front turn signal circuits from the additional circuits I am adding?
Anybody know the easiest place to tap into the front turn signal circuit?
