Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
4+4 shake
Old Feb 26, 2007 | 02:38 PM
Fattony's Avatar
Fattony
Default 4+4 shake
I have a 2006Ram 1500 4+4 . The problemis when you put the truck in 4w hi and accelerate fairlyaggressivley or justaccelerate pulling a trialer (snowmobile trailer) the truck shutters . I've taken it back to the dealermany times with no change, now they tell me all of the 06-07 do this. it's a problem the enginers are working on . Sounds like BS is it does anyone else now of this problem?
Old Feb 26, 2007 | 04:29 PM
Captain Squalus's Avatar
Captain Squalus
Default RE: 4+4 shake
It sounds like your on a road surface that does not require the use of 4x4.
Independent front suspension on a 4x4 will shimmy under a high load condition. (ie: too much power with too much traction)
On a good traction surface with too much power applied the toe-in on an independent front suspension will increase and cause a shimmy. (see the attached vidio for extream example)
Why not to buy a Duramax
http://www.youtube.com/watch?v=iT6Lqj-_eSo
Old Feb 26, 2007 | 08:13 PM
CatchMyDrift05's Avatar
CatchMyDrift05
DAMN CaptainSqualus!! That Truck in the VID has a SH*T load of Torque!!! Bump for good post and BUMP for that vid....
Old Mar 1, 2007 | 07:41 PM
Inferno06's Avatar
Inferno06
Fattony,I have the same problem,check out this forum linkhttp://hemitruckclub.infopop.cc/eve/...2/m/8660020274
Old Mar 1, 2007 | 07:48 PM
MoparMJM's Avatar
MoparMJM
It is a fairly common issue... how fast are you going when you do this?
Old Mar 1, 2007 | 08:07 PM
Inferno06's Avatar
Inferno06
It will do it from a dead stop all the way up to highway speed, the more load (pulling something or going up steeper grades) the more pronounced, smoothes out with lighter throttle.
