Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
ram y-pipe/cat
Old Dec 25, 2003 | 11:50 PM
5.9rm's Avatar
5.9rm
Default ram y-pipe/cat
i am trying to find a new y-pipe and cat that i can bolt into my '99 5.9l ram. the old cat it the original (130,000 mi.) and has got to be worn out by now. i was looking under my truck, and it appears that the y-pipe and the cat are all wleded together until about a foot before the muffler.this would lead me to belive that i would need to replace the whole section as one unit.</P>
also, regarding cats, the one on my ram has two inlet pipes and one outlet. also, it has the o2 sensor in one of the inlet pipes.all of the high flow aftermarket cats that i have looked at have one inlet and one outlet pipe. is there a manufacturer that produces stock replacement high flow cats for the 5.9l dodge ram? or am i going to have to go through the dealer on this?</P>
aaron</P>
Old Dec 26, 2003 | 02:14 AM
clarson80's Avatar
clarson80
I just changed my old cat (really worn out) at 125K. I found a cheap Magnaflow high flow cat on Ebay (75 bucks plus shipping!<IMG src=smileys/smiley20.gif border="0">). I also put a new Magna flow muffler and duals out the back after that. Big power difference, I highly recommend changing it all out, especially since the cat is the most expensive part, and more power is always good!</P>
I know that Magnaflow makes a "two in-one out" cat. And I did not have to replace the Y-pipe. I didn't do it myself, I had a local shop do it, and the mechanic did say the y-pipe had to come out to get the cat off (because they are welded together). At least he told me before hand, that was what he would do, didn't ask if he actually had to.</P>
He said dodges are a real"you know what"to change cats on....so if you can, just have a local shop change it,it may be a real headache. They can order a cat for you, but they are usually at least $150 from what my mechanic said. I would recommend asking you local shop to do it, and see if they don't mind if you find your own cat somewhere for cheap and just bring it in. </P>
oh...and while your changing the cat, you might as well change the 02 sensor. and yes, they are in the front of the cat, but i do believe it is in the cat, so it is reading both inlets (I think)</P>
hope this helps</P><edited><editID>clarson80</editID><editDate>37980.9693518519</editDate></edited>
Old Dec 26, 2003 | 05:47 AM
5.9rm's Avatar
5.9rm
thanks for the reply, it helps a lot.i just replaced my o2 sensor, so thats all peachy, and i can weld, so i think i can handle the install. but i'll ask my local muffler shop about it too.</P>
aaron</P>
