Bedliners Spray Vs Drop In
The one thing I liked about my drop in bed liner was the fact that it absorbed impact a lot better than my spray in liner. I could throw anything in the drop in bed liner and never worried about causing a dent. However, I would still suggest getting a spray in bed liner. After 9 years, the drop in bed liner essentially took off all of the paint in my bed.
ORIGINAL: bryanp56
Are the do it yourself brush on/spray on liners any good?
This truck is at my shop right now. We are going to apply LINE-X Xtra (a gray color match) on the entire exterior of the truck. It has a do-it-yourself bedliner in it and we're going to strip it out. It's worn and chipped in many areas. Here's some pics:
http://img.photobucket.com/albums/v4...e/GrayExt1.jpg
http://img.photobucket.com/albums/v4...e/GrayExt2.jpg
http://img.photobucket.com/albums/v4...e/GrayExt3.jpg
I sell Bedrugs also and yes, it is carpeting. It's closed cell poly knap, like indoor/outdoor carpeting. Bedrug is a good product, just wash it out to clean it. Twigs, leaves, etc. tend to get caught up in it though. I do not recommend it for work trucks, the knap will tear with heavy duty use. Otherwise it's OK for the occasional truck bed user.
I just bought my Ram this past week end and the dealer sprayed in Alpha liner before I picked. Probably the best investment in the truck. Right there alongside with synthetic fludis. Great Stuff but just becareful with slamming stuff into it. I hear the metal underneath is still prone to denting. Good Luck.
With a drop in liner you paint may wear off with time but it should ne rust unless you gouge the metal real deep. It is made of Galvanized steel. Galvanized steel has gone through a chemical process to keep it from corroding. The steel gets coated in layers of zinc because rust won't attack this protective metal. For countless outdoor, marine, or industrial applications, galvanized steel is an essential fabrication component.So the rhino liner guys (HORROR) pics are to get you to buy the product.
I have a Rhino spray in bedliner on my F350 work truck. It has held up to moderate use, however, it has quikcly faded to a dark grayish color and if you rub it with your clothes or sit on it, the color transfers to your clothes. The thing is 1 year old and looks like crap. I won't spray my own truck with it because of this. My truck came with the generic drop in from the factory and that will work for now.
I had a BedRug on Lightning which had a tonneau cover. It was really nice and looked great. I also wouldn't use it in any type of work truck. If I ever get a tonneau, I may add one in the Ram too.
