Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Multiple Drive train issues.
Old Mar 28, 2007 | 09:29 AM
brooksdg's Avatar
brooksdg
Default Multiple Drive train issues.
I'll try to keep this short....
I own a 2003 Ram 2500 (Quad cab LB) 4X4 w/ the HO Cummins and a 6-speed. Truck currently has a little over 88K with no mods, just regular maint. Miles are a majority highway, when driven round trip is 110 miles. Hasn't had the chance to tow anything yet and the biggest load was a palette of Lime for the local football league.
So back in early 2004 I took the truck in for what felt like a slipping clutch. The dealer tells me the driveshaft is out of balance and replace it under warranty.
Then in 2005 she goes back because there is a moan at about 23-25MPH. Dealer writes this off as bad synchros between 3rd and 4th and replace the transmission. Truck had maybe 55-60K on it at this point, I've since bought another car and split time between them. When I'm leaving the dealer after the trans work I still hear the moan. The dealer then starts an investigation with Dodge. They tell me the moan is actually the middle bearing in the driveshaft. They say its a known issue but they haven't come up with a fix yet. Guess the good news would be I got a new trans out of it....
Last week, the weather was getting better and I had the truck out windows down. From a stop as I let the clutch out I hear a rubber on metal squeaking sound. It does away as soon as the clutch is all the way out and doesn't last that long. My first concern is the driveshaft bearing, I've always thought the problem there was lubrication since it really did it more in cold weather and seemed to go away as it 'warmed up'. So I take the truck to the dealer (thank you ext. warranty) and they tell me I have at least 1 bad U-joint and they will replace all of them (4) under warranty.
I asked the service mgr if I should be overly concerned that I've had my "Heavy Duty" truck in there so many times fir driveshaft issues. To me the 3-4 times I've been there is 4 years is excessive, maybe I'm wrong. He pulls my history and runs down when and what was done. Then looks up at me and says 'Nah I wouldn't be concerned. They are very durable trucks'. (WTF am I here for then).
So my question is has anyone else had similar problems? Is this a known issue with these trucks? I was sort of nervous about getting the 03 since there were some 'new' things introduced that year. I don't' see TSB or recalls on them for this though. Is there a way to express this concern to someone above the dealer? If so who? One of my biggest concerns is I'll be doing this again and again every year and a half without the warranty umbrella.
Thanks.
Old Mar 28, 2007 | 02:12 PM
sabersix's Avatar
sabersix
Default RE: Multiple Drive train issues.
Welcome to the forum, brooksdg!
No answer for you, but you'll get better response if you post your question in one of the sub-forums, 3rd gen or cummins diesel.
Old Mar 28, 2007 | 03:37 PM
brooksdg's Avatar
brooksdg
thanks I'll repost and delete this one.
Old Mar 28, 2007 | 03:44 PM
brooksdg's Avatar
brooksdg
I sent PM to admin asking for this thread to be delete. Moved it to Cummins sub-cat.
