Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
K&N Air filter
Old Apr 7, 2007 | 01:04 PM
sprinterpop's Avatar
sprinterpop
Default K&N Air filter
Just added a K&N Airfilter. I normally fill at a half-tank and it looks like the mileage is up by about 1 mpg to ~21 mpg. Slightly more intake noise, but not objectionable. It installed easily, but you do have to be cautious to get the sealing rib aligned in the air box lid. The K&N edge molding is more floppy than the OEM air filter.
Old May 24, 2007 | 05:56 PM
Driver Tom's Avatar
Driver Tom
Default RE: K&N Air filter
What kind of mileage are you getting?
We averaged a little over 18 mpg with our 2007 diesel shorty.
Old Sep 12, 2007 | 12:23 AM
ratchett11's Avatar
ratchett11
Only problem with running a K/N air filter is if you don't keep it clean and oiled every couple of thousand miles dirt will get through it into the turbo then you have big problems. If your still within factory warranty and you have a turbo failure and they relate it to the K/N because they can see where the turbin has been sand blasted so to speak the warranty will not cover the repairs needed. Food for thought.
