Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
Power locks
Old Apr 19, 2007 | 03:04 AM
Doo Hauler's Avatar
Doo Hauler
Default Power locks
Can the power locks be disabled or modified so I can leave the keys in the ingnition and still use the keyless to lock/unlock the doors? This has been a problem I am using the van for package delivery and need to lock the doors when leaving the van unattended but depending on weather conditions I may leave it running.
Any ideas?
Thanks
Joe
Old Apr 19, 2007 | 09:40 AM
stp57's Avatar
stp57
Default RE: Power locks
You need to purchase a mechanical key & have the locksmith cut it for you. The key blank # is MB17. If your local locksmith doesn't have it, Sunshine Locksmith will: http://www.sunshinelocksmith.com/locksmith-index.php
I paid $6 (shipping included) a key blank, but it should be cheaper if found locally. This key will allow you to lock & unlock the van with it running, but it will not start the vehicle.
Steve
Old Apr 20, 2007 | 01:23 AM
Doo Hauler's Avatar
Doo Hauler
I don't think I am understanding what you are saying, or perhaps you don't understand my needs. I have 4 keys for the van all with remote entry. I need to be able to use the keyless entry to lock/unlock the door with the van running or not.
Basicically I want to leave a key in the ignition at all times and be able to lock/unlock the doors with any of the 3 remaining keyless reomte entry key fobs. Is this possible?
Thanks
Joe
Old Apr 20, 2007 | 01:38 AM
stp57's Avatar
stp57
I knew exactly what you meant, Joe, but it could never happen in the Sprinter. The MB lock mechanism is already over-engineered as it is; it locks one door, then all doors, then none. Locking the door with a mechanicle key (MB17) is the only way that you can get away with leaving the keys in the ignition. I keep one in my wallet. Try that with a transponder key...ouch!
Steve
Old Dec 8, 2007 | 09:56 AM
maggie2006's Avatar
maggie2006
$100 fix. Go to your local aftermarket remote lock man and have him install a unit. I used a guy in Colorado Springs. You get a second remote that you can carry on a chain or in your pocket that will lock and unlock all the doors at once with a single click. Your oem remote will still work but it may get out of sequence and take a couple of clicks to do what you want but otherwise no problems. My van runs from dispatch to end-of-day and is always locked when I'm away from it.
