Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
HID headlamp conversion 2007 sprinter
Old Mar 19, 2008 | 01:21 PM
madchuck's Avatar
madchuck
Default HID headlamp conversion 2007 sprinter
Does anyone know how I can change my stock headlamps on my van. I have a set of hid kits but they will not work with the on board diagnostics because the current of the ballasts are too high, it says low beam failure on the dash. I even tried running a relay in the place of the bulb and it still shuts the lamp down and says low beam failure. I tried putting a .003 ohm resistor in line to make it think there was a lamp still there and even that didn't work. Any help would be appreciated.
