Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
adjustable dim headlamp
Old Jun 20, 2008 | 06:49 PM
viewsie's Avatar
viewsie
Default adjustable dim headlamp
I have a Winnegago View on a 2006 3500 sprinter chassis. The headlamp level adjustment mechanism does not work, although it has been serviced 3 times. Even had a new headlamp motor installed.
I would like to know if anyone knows if there is a way to manually adjust the headlamp to keep it in the higher level position. I have to use my fog lamps in addition to the head lights for night driving, because since the dim lamp is stuck in the lowest position, visibility is minimal.
Thank you.
