Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
Sprinter Questions Please help
Old Jul 10, 2006 | 02:59 AM
compacttuner's Avatar
compacttuner
Default Sprinter Questions Please help
Hi, I am wondering where the power outlet at base of seat is exactly located because I just picked up my Sprinter and it says that it has it on the sheet but I cannot find it? The tire size that came on it is 225/75/16, can I put a slightly different tire on it without it changing the speedometer and mileage. I want to put winter tires on it in a couple of months but none of the manufacture's for winter tires seem to carry that size. Thanks for any help in advance.
Old Jul 11, 2006 | 12:54 PM
gizmo uk's Avatar
gizmo uk
Default RE: Sprinter Questions Please help
Should be able to go slightly wider with the tyre,can't comment on power output,mine does'nt have one.Recommendhttp://www.sprintervan@yahoo.comfor any techy questions.
Old Dec 29, 2006 | 08:45 PM
sprinterman's Avatar
sprinterman
If you are sitting in the drivers seat, on the right hand side you will see a silver circle on the metal base about 4 inches up..That is the power outlet. The only problem is that it is a european style. It almost looks like a hole you would plug a guitar cord into.
