Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
need help with brakes
Old Aug 4, 2006 | 05:44 PM
tampasprinter's Avatar
tampasprinter
Default need help with brakes
I have an 02 sprinter with @75k mi on it and will be replacing the pads for the 3rd time in one year. the peddal has always felt funny since i had work done at dodge dealer I have bled system but the peddal still feels light any help would be much apriciated thank you
Old Aug 23, 2006 | 12:41 AM
yerocniluh's Avatar
yerocniluh
Default RE: need help with brakes
first of all make sure your getting the right pads nd replace the rotors (from local dodge dealer/and don't remove the coating)as for the
pedal naturally you'll want to check for hydraulic leaks (both internal and external) and make sure you use dot-4 brake fluid.
i would definetly c/k for contamination (water).the right way to bleed the hyd. system is w/the exceptional bleeding procedure wich
is availible w/a scan tool able to communicate w/the CAB module
