Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
fuel filter change
Old Aug 26, 2006 | 09:47 PM
jemepa's Avatar
jemepa
Default fuel filter change
Hi,Ijust change my fuel filter without knowing that I had to diconnect neg. cable and now my fuel pump dosn't work.Did I burn it or is there any way to reset it? I check the fuse,it's fine.Any ideas,Thank you.
Old Jan 30, 2007 | 08:58 PM
Monzsta's Avatar
Monzsta
Default RE: fuel filter change
You likely just have it full of air. Assuming you haven't cut any o-rings, put a battery charger on it and crank it for 30 second intervals, giving it 30 seconds to cool. It will take a while to work the air out, but it will eventually. if it still doesn't start, examine the o-ring on the clear line going to the center of the filter. It is real easy to cut this one putting it back on.
