Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
front wheel bearings`
Old Mar 21, 2007 | 07:03 PM
shagybruce's Avatar
shagybruce
Default front wheel bearings`
anyone replaced the front wheel bearings on a sprinter? i have a 2005.is it just inner and outer and seal?? anything i should know???
Old Mar 21, 2007 | 08:16 PM
4ADAM 12's Avatar
4ADAM 12
Default RE: front wheel bearings`
I have removed the dust cover to make sure there was enought grease once. I have also had all the bearing in the front replaced at one point. The spindle nut is not realy a nut, by this I mean it does NOT thread onto the spindle. If I remember correctly you'll need either an allan wrench or more commonly used on these vehicles a torx bit to remove the spindle nut. From what my mechanic told me it is just inner and outer and axle seal, not to sure if there is an inner and outer seal. I get back to you when I check the Dymler Chrysler repair manual disc I have.
Old Mar 21, 2007 | 09:19 PM
shagybruce's Avatar
shagybruce
4adam12 if i had access to a repair manual no problem maybe you could e mail me a pdf file relating to the fromt wheel bearing replacment...thanks steve
Old Mar 22, 2007 | 11:52 PM
4ADAM 12's Avatar
4ADAM 12
I didn't forget about you, I'm working on uploading the entire FSM. I hope my buddy at RSPEED.ORG comes thru for me. He's setting up a FTP. Apparently I have adobe pdf viewer, not the full version where I could copy the pages.
Old Mar 23, 2007 | 06:05 PM
shagybruce's Avatar
shagybruce
hey not a problem take your time thanks again
