Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
IAC resistance
Old May 9, 2007 | 12:20 AM
zoso's Avatar
zoso
Default IAC resistance
My car has been idling weird for a couple weeks so I checked out stalth 316 and looked at the IAC page. I checked the resistances and all were fine except 1 and 2, which was about 2 ohms. Is the only way to fix this to buy a whole new IAC?
Old May 9, 2007 | 12:21 AM
zoso's Avatar
zoso
Default RE: IAC resistance
Also, I checked the ECU and the capacitors and board were all fine.
Old May 9, 2007 | 02:36 AM
EvilZombieZ's Avatar
EvilZombieZ
Even if there is a way to fix it I would just buy a whole new IAC, old car so things are gonna need replacing. Just like if you buy 1 axle its good to just buy both. More parts you replace rather then fix, the better off your car will be in the long run.
Old May 9, 2007 | 12:49 PM
thestealth's Avatar
thestealth
The IAC can be rebuilt. They are pretty expensive from the dealer (dealer only item). The best price from a dealer I've found is through Rockville Mitsubishi. It was cheaper with shipping than anything I could find local.
