Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Key won't turn. HELP
Old Jul 3, 2007 | 10:26 PM
spunky2552@msn.com's Avatar
spunky2552@msn.com
Default Key won't turn. HELP
I just purchased a 1991 Stealth R/T TT and the clutch pedal has to be exactly the right spot to be able to turn the key. It is very tricky to get it in just the right spot.
Has any one else experienced this problem? If so what was the fix.
I'm thinking the key might be worn or the ignition switch needs to be replaced.
Old Jul 5, 2007 | 11:24 AM
92stealth's Avatar
92stealth
Default RE: Key won't turn. HELP
you sure the steering wheel isnt just locked? wiggle the steering wheels when you go to turn the key, that might help.
