Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Changing Transmission Fluid help :)
Old Jul 5, 2007 | 09:23 PM
Blink_Jason's Avatar
Blink_Jason
Default Changing Transmission Fluid help :)
Well after reading "zoso"'s post about his gears shifting badly, i think im going to change the transmission fluid this weekend, how much does it take, what type should i use, and anything else that will help me out (like where and how to do it)
Thanks -Jason
Old Jul 5, 2007 | 09:41 PM
Blink_Jason
Default RE: Changing Transmission Fluid help :)
hmmm lol i found this...this seems just about right doesnt it?
http://www.stealth316.com/2-awddrainfill.htm
Old Jul 5, 2007 | 11:19 PM
thestealth's Avatar
thestealth
I used his walkthrough myself. I went with Pennzoil SyncroMesh gear oil.
Old Jul 5, 2007 | 11:44 PM
Blink_Jason
well this will be my first time doing it i have no expierience... any tips?
Old Jul 6, 2007 | 08:34 AM
thestealth's Avatar
thestealth
Make sure the car is level. Drive it around for a little while to warm up the fluid. Don't over tighten the fill/drain plugs, the plugs are steel, the casing is aluminum, if you over tighten it you can strip out the casing. That's about it really.
