Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
twint turbo engine?
Old Aug 3, 2007 | 12:06 PM
t4dude's Avatar
t4dude
Default twint turbo engine?
http://www.japanracingengines.com/engineview.asp?id=32the link to the engine. it comes with everything transmission ecu both turbos the works.
Alright I forgot to mention in my other post of what im doing to my car i also had planned on dropping the 6g74 3.5 doch 24v engine in becuase it is stonger then the n/a 6g72 2 bolt main. It can handle alot more psi from that supercharger and puts out more hp plus it can be stroked to a 4.1. But now i found this If i got this i would keep it tt and not super charge. My ? is will it work if i swap the tranny? That tranny is for the awd mine is not it does not come with the rear drive shaft does it? or how much more would it be just to convert it to awd? HELP I only have 2 more days to cancle my order on the 6g74
Old Aug 3, 2007 | 09:19 PM
yevgenievich's Avatar
yevgenievich
Default RE: twint turbo engine?
to convert to AWD you would need rear axle from AWD car.Converting to AWD is not cheap. The trans that you have should be able to bolt on to it but it might not be able to handle the extra power of tt.
Old Aug 4, 2007 | 12:23 AM
t4dude's Avatar
t4dude
Alright so i got the tt engine complete with ecu and everything, the twin turbo 5 spdawd tranny the transfer case and the drive shaft and the front and rear hubsnow all i need is axel? is this correct
Old Aug 4, 2007 | 11:38 AM
thestealth's Avatar
thestealth
You need the whole rear subframe from an AWD car. You need custom mounting points welded in so you can bolt in the subframe.
Old Aug 4, 2007 | 11:39 AM
yevgenievich
looks like you have all the parts, but i think you would have to fabricate special mounts insome places bcause now you would have active rear axle and extra weight of transfer case.
Old Aug 4, 2007 | 11:47 AM
thestealth's Avatar
thestealth
If you decide to use the AWD tranny in FWD mode you have to weld the VCU. Please go on 3si and search for a bad VCU as the can be welded and will work fine for FWD duty.. There is a finite supply of VCU's, so don't use (waste) a perfectly good one for the conversion.
