Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Ignition Failure/shut down
Old Aug 27, 2007 | 11:14 AM
xcrashx's Avatar
xcrashx
Default Ignition Failure/shut down
I have a 1992 Dodge Stealth Twin Turbo. Recently my vehicle has developed a problem. When it's first started in the morning or if it's sat for a while it will start fine and drive. If I've driven it and let it sit for a short period of time it will start and then it will shut down. The whole ignition system shuts down. Once in a while when I'm driving it will shut down while I'm driving then start back up. Any Suggestions? Similar Problems? Thanx.
MB
Old Aug 27, 2007 | 11:35 AM
thestealth's Avatar
thestealth
Default RE: Ignition Failure/shut down
ECU capacitors are probably leaking.
Old Aug 29, 2007 | 10:13 AM
xcrashx's Avatar
xcrashx
I'll try that next, just went through and replaced all the ground wires and upgraded them to four gauge thinking it was shorting out or not creating enough of a ground.
Old Sep 12, 2007 | 05:09 PM
fnkecldmedina's Avatar
fnkecldmedina
control modual mounted on manifold next to the dist. cap
Old Sep 12, 2007 | 05:41 PM
thestealth's Avatar
thestealth
The PTU? It's under the coil packs. They will go bad and cause a coilpack to not fire...but when they go bad, they usually go bad...not work intermittantly.
