Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
cranks but no start
Old Aug 28, 2007 | 07:24 PM
moparman139's Avatar
moparman139
Default cranks but no start
had a drivability problem, to start out with. hooked up a snap on scan tool to pull codes. the scanner could not communicate with ecm then my car would not start at all. think i may have spiked the ecm, any other ideas or things i could check???
Old Aug 28, 2007 | 07:49 PM
thestealth's Avatar
thestealth
Default RE: cranks but no start
What year?
Maybe a fuse, maybe a coincedence, I don't know.
Old Aug 28, 2007 | 08:25 PM
moparman139
1992 ES the first problem was it would backfire thru the exhaust and barely run, intermittently then run fine.
Old Aug 28, 2007 | 08:26 PM
moparman139
checked fuses several times, they were good.
Old Aug 28, 2007 | 08:41 PM
thestealth's Avatar
thestealth
From the symptoms you described there is a good chance the ECU was going out beforehand. Hopefully you didn't cook it beyond repair.
On a 92 you can check the codes with a simple analog voltmeter.
Old Aug 29, 2007 | 06:48 AM
moparman139
thats what i was afraid of. could the ecu cause the backfiring and rough idle problem? i thought it might have been the injectors. it has 125000 miles on it and wasnt taken real good care of before i got it, i did the 60000 mile maintenance and changed the plugs and wires and water pump that was about 20,000 miles ago. i live in chicago anyone know where i could have the ecu checked near me??
Old Aug 29, 2007 | 07:55 AM
thestealth's Avatar
thestealth
You could check around at some chain type autoparts stores, see if they have one you could buy. If it works, great, turns yours in for the core, if it doesn't, back the drawing board.
