Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
TCU
Old Sep 7, 2007 | 10:26 PM
daisy92's Avatar
daisy92
Default TCU
have a 92 stealth r/t auto. can i use the tcu from a 93 up stealth?
Old Sep 8, 2007 | 11:19 PM
yevgenievich's Avatar
yevgenievich
Default RE: TCU
i think 93 was still at least partly first gen, second gen is slightly different but tcu might be the same, have you checked if the part number is same for all years?
Old Sep 9, 2007 | 12:53 AM
daisy92's Avatar
daisy92
Default RE: TCU
i saw a tcu on ebay. and they got 2 kinds. 90-92 tcu $295. 93-96 $175. what do you think? you can check it on ebay. really need help. thought it was just my capacitors. so i bought some at digi-key.com. but then when i took it to the shop some parts on the board are already missing. i think it got burned really bad. the tcu on ebay was a rebuilt one.
Old Sep 9, 2007 | 09:38 PM
EvilZombieZ's Avatar
EvilZombieZ
Default RE: TCU
93 is a first gen tcu, 91-93 is first gen. I have a tcu from a dohc and my car is sohc and it works fine, so I dont see why a 93 wouldnt work at all.
Old Sep 10, 2007 | 12:53 AM
daisy92's Avatar
daisy92
Default RE: TCU
thanks. i'll let you know as soon as i swap tcu with some friend.
Old Sep 10, 2007 | 07:15 PM
workinprogress's Avatar
workinprogress
Default RE: TCU
sohc tcu is different than dohc and 93 and up is not the same as 91-92 the 93 has 4 plugs instead of 3
a tcu out of a 92 diamonte however is the same as a dohc stealth and alot easier to find in the bone yard.... just be sure to put in new capacitors befer usin it.... 91 and 92 tcus had the same problem as the ecus.
been there....... done that.......
