Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
upgrade
Old Sep 28, 2007 | 06:04 PM
tokex420's Avatar
tokex420
Default upgrade
I was wondering I have a stock 94 tt and I need to get some new turbos. What would be the best solution, getting replacements or is there anything i can get better without making any other mods, and where can I get a good deal.
Old Sep 28, 2007 | 10:28 PM
yevgenievich's Avatar
yevgenievich
Default RE: upgrade
i belive 3sx is selling larger turbos.
Old Sep 28, 2007 | 11:30 PM
thestealth's Avatar
thestealth
Default RE: upgrade
If you are just wanting a small bump in power, the 13g's are a good, bolt on way to go. You can run them with minimal mods, since they are the size turbo's the Euro GTO's (3000gt) had.
If you want a little more, check out Dynamic Racing's DR500's. You will need some mods to run those safely, but they are what I would consider the next step up. There are a few guys on 3si that can modify your stock 9b's for more power.
When upgrading turbos, you'll need to upgrade the fuel delivery. The stock system will not keep up with much bigger turbos than stock. If you plan on running more than 10-12lbs of boost, get a real gauge and a datalogger.
Old Sep 29, 2007 | 01:30 PM
tokex420's Avatar
tokex420
Default RE: upgrade
If i upgrade would i need to get an intercooler as well or maybe some headers first. Or would the fuel injectors and fuel pump be enough to maintain the upgrade.
And would you have a estimate on how much all those options would cost
Old Sep 30, 2007 | 08:20 PM
tokex420's Avatar
tokex420
Default RE: upgrade
Also can you rebuild your turbos, mine are 120,000 miles and leaking.
would it be better to replace them or rebuild them.
Also you saidI can send themto 3si and have them modify my stock ones, but which would be the best option.
Old Oct 1, 2007 | 10:27 AM
thestealth's Avatar
thestealth
Default RE: upgrade
Yes, turbo's can be rebuilt, relatively cheap compared to the cost of new ones.
There are guys on 3si that upgrade the stock housing. 3si is a forum, you'd have to search around to find out who as I can't recall their names off hand. I want to say Rob Beck and markoverclock are their screen names.
If you are happy with stock power, just get yours rebuilt.
Old Oct 19, 2007 | 12:40 AM
tokex420's Avatar
tokex420
Default RE: upgrade
when rebuilt for more power are they like new or is there somethings they cant do, like shaft play if i have that can they get rid of that, and how do they give it more power.
Also would you know how much it would be like a rough estamate?
Old Oct 19, 2007 | 08:35 AM
thestealth's Avatar
thestealth
Default RE: upgrade
To my knowledge, when they rebuild them, they are as good as new. Have you checked out Dynamic Racings DR500 series of turbos?
Old Oct 19, 2007 | 03:05 PM
tokex420's Avatar
tokex420
Default RE: upgrade
I hope it would be like new But no I havent checked out those turbos, are the a stock replacement or are they an upgrade so I would I have to upgrade my fuel?
ALSO would you know about how much they would rebuild them for?
Old Oct 19, 2007 | 04:31 PM
thestealth's Avatar
thestealth
Default RE: upgrade
They are an upgrade from stock.
I've never had the need for rebuilt turbo's (yet), so I've never researched prices...
Check out dynamic racings turbo upgrade section. If I recall correctly, it says what all you need to safely run those turbos.
