Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
ES from Holland with troubles
Old Sep 30, 2007 | 04:45 PM
xantros's Avatar
xantros
Default ES from Holland with troubles
Hi guys. I have some issues with my 1992 Stealth ES 3.0 DOHC-24v. Since a while the car has gotten more problems in just running normaly. I really need some help as there are no dealers or mechanics here to help me.
The car became very slow and runs rough since two months now. No more power than an handicap or golfcar. When trying to accelerate the engine studders violently and behaves like it is running on 3 or 4 cyl. only. A lot of plopping sounds in the exhaust. Switching the power/eco button doesn't make any difference anymore. Sparkplugs (3 sets used), Wires, Fuel Filter, and Air Filter allready replaced, but no difference att all!! Not the slightest. The engine was then tested for ignition problems but came out allright. After a CO2 check we found out the car had totally no CO2, so it is running on a very poor fuel air mixture. When running the engine in neutral nothing seems to happen. I am totally out of options.
Now I have read this complete forum and read several issues with the ECU. Now it is very difficult to get parts for the Stealth here in Holland, is there an option to test the ECU? Something like an emergency programm the car can run on? So I really know it is the ECU to blame.
Or pherhaps any other options I can check? I really need help. Thanks in advance guys.
Old Sep 30, 2007 | 05:26 PM
yevgenievich's Avatar
yevgenievich
Default RE: ES from Holland with troubles
pull the esu out and see if capacitors are leaking. Even being in holand you should be able to send it to rebuilding place, it is going to cost about $30-$60 to ship it tho. Sure way is to pull it out and see if the capacitors been leaking.
Old Oct 1, 2007 | 05:01 PM
xantros's Avatar
xantros
Hi its me again. Today I took the ECU apart and saw that one CAP was leaking. Went to the nearest electronics shop and replaced the cap. How ever no change in the driving behaviour so far. Also today I have ordered a new Walbro fuel pump. This will be ariving wihin ten days. I will keep posting this issue untill I have solved this problem. However if somebody has some more tips for me where to look I will be very graithfull..
Cheerz from Holland
Old Oct 1, 2007 | 08:15 PM
EvilZombieZ's Avatar
EvilZombieZ
If it leaked it could of damaged the ecu.
