Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Automatic Stealth has trouble shifting
Old Oct 8, 2007 | 02:49 PM
J.Blac757's Avatar
J.Blac757
Default Automatic Stealth has trouble shifting
Okay this is an off and on problem
i recently drove down my stealth from Virginia to Florida
which is about an 11 & half hour drive
anyway after arriving to florida the next morning
i take my mom to the airport and i notice my automatic shifting is going crazy again
It takes a while for it to shift gears and when it does i get a real bad shift shock
even when switching to reverse it takes longer than normal
I had this problem before but it went away, but now its back
any ideas on what the problem is??
Old Oct 8, 2007 | 11:45 PM
yevgenievich's Avatar
yevgenievich
Default RE: Automatic Stealth has trouble shifting
could be tcu, i would check that first because i belive it have same problem as ecu, which is leaking capacitors. Then i would check mechanical, meaning rebuild.
Old Oct 9, 2007 | 07:54 AM
workinprogress's Avatar
workinprogress
definatly sounds like a tcu.......
Old Oct 9, 2007 | 04:52 PM
J.Blac757's Avatar
J.Blac757
so should i go to a dodge or mistubishi dealership
and ask someone to check my TCU??
and will this cost me anything (im low on money)
Old Oct 9, 2007 | 05:47 PM
invsbl1's Avatar
invsbl1
send your tcu to ecmtogo of houston texas, they'll test it for free and contact you with the problem. type in ecmtogo(all one word) on the internet. very helpful people.
Old Nov 7, 2007 | 03:22 PM
godsdisciple85's Avatar
godsdisciple85
I have a dodge stealth r/t with ecs for some reason the car will not get out of second gear from start of car and on... also the tour sport light is flashing on the car and the abs light stays on. Do you think this could be an electrical issue causeing all of the problems or are these problems all seprate?
Old Nov 7, 2007 | 04:57 PM
yevgenievich
sounds like tcu
