electrical problum
me and my friend went 2 carowinds and when we got there after a 2 hour drive, my brake light, battery light and radiator light came on, on the dash. but they would only come on when the carwas under 2000 rpms, when we had it over 2000 they would go away. the battery gage was also on twelve and then 8, i think something could be draining it buti dont know what ? could someone please help me ? thanks...
The same thing happened to me a ways back. Does the car sputter then die when you come to a stop? Does putting the car in neutral, and revving the engine keep it from sputtering? Do the inexpesive stuff first. As strange as it may sound, try gettting new battery cable terminals. Check to see if they are corroded or if corrosion is built up on the battery terminals. I replaced mine and the problem went away. No more dash lighting up like an xmas tree. If that doesn't solve it, try the battery and new cables. Hope that gives you somewhere to start.
no the car does not sputter or die but it is just running of the battary after a while the battary will go down to 8 volts and then die i was working on it a while last night and somtimes i could get it to 14 volts and then it would go back down to 12 volts but it is got all new alternator battary and belts. i was trying to get the big fuse out last night is under the hood but it wouls not do you thank that could be the problem thanks...
