Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Clutch problem?
Old Nov 21, 2007 | 08:14 PM
stealth66's Avatar
stealth66
Default Clutch problem?
First of all I would appreciate any help/advice. I have a 93 r/t non turbo 5 spdwith 100k miles. Sometimes my clutch pedal stuck- in which I could pull back and was functioning again. The last time just ready to leave in the moorning and my pedal just fall to the floor without any resistance. I changed the clutch slave cylinder and probably got all the air out. Now the clutch is working but it used to engage about midway and now it is right at the floor. Could this be because of the new slave cylinder? Maybe still some air in the line altough pumping the pedal did not make any difference. Honestly I just do not want to change the master cyl if Im not sure that that is the problem. It seems to be a lot of work.
Any advice maybe some of you went through this already??
Thanks
David
Old Nov 21, 2007 | 08:30 PM
yevgenievich's Avatar
yevgenievich
Default RE: Clutch problem?
mine engages almost at the floor, maybe there is some adjustment needed? but i never had to mess with that so not sure
Old Nov 21, 2007 | 10:14 PM
Blink_Jason's Avatar
Blink_Jason
mine engages past the floor! gotta push that pedal WAY down and still my gears grindzor
Old Nov 22, 2007 | 06:41 PM
Danny~G's Avatar
Danny~G
did you check to see if the master cyilender is leaking
Old Nov 23, 2007 | 11:17 PM
stealth66's Avatar
stealth66
I just finished with it and shortly just changed the slave cylinder which seemed at first helping the problem but not the release at the floor. I ended up under the dash adjusting yhe rod of the master cylinder which solved the problem and actually it is pretty easy to do
Old Nov 30, 2007 | 11:53 AM
Love my 93Stealth's Avatar
Love my 93Stealth
I just went through all this with the same make and model, with about 90K on it. Clutch is good. Thought I'd post so other people would know that this can be there problem also.
Regards!
Old Nov 30, 2007 | 07:46 PM
Blink_Jason
ORIGINAL: Love my 93Stealth
Regards!
clutch is the problem, or isnt the problem?
