Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
OD not working
Old Nov 29, 2007 | 06:00 PM
zkstealth's Avatar
zkstealth
Default OD not working
bought 1993 dodge stealth automatic for my son and the OD is not working. it is like it drops to neutral when OD should engage. any suggestions? also need to find rim at reasonable price for the car--one is bent from previous owner.
Old Nov 29, 2007 | 07:13 PM
yevgenievich's Avatar
yevgenievich
Default RE: OD not working
do you need 15" or 16" rim? i have 15" but it's a set of 4. I would recomend junk yard, altrough i coud never find a stealth at local junk yards. As for OD not working, i would check tcu just incase for leaking capacitors
EDIT: actually i remmeber seeing half of a stealth at one junkyard in college station area, and i remembered about one comlete with 16" wheel in this area as well. Originally i refered to north of Dallas area
Old Nov 29, 2007 | 08:12 PM
stealth29032's Avatar
stealth29032
The problem with ur OD is the end clutches. I have a 91 r\t automatic had same prob, like it was in nuetral. IPTTRANS.com sells a kit to fix this for 90 bucks and i went online and googled stealth end clutch replacement and there is a guy that has a step by step with pics that he did on an eagle talon, very easy fix, did it in driveway in 2 hrs! Hope this helps u!
