Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Problem with gas getting to engine.
Old Dec 6, 2007 | 11:21 PM
Dcterluv's Avatar
Dcterluv
Default Problem with gas getting to engine.
This has just started happening within the last two days. It started after I got stuck at the end of my driveway in a pile of snow, not sure if that has anything to do with it, but it will start up then I can drive for a little while, then when i park it will not start, it will turn over but will not run. Also today, I was driving and it shut off on me while driving, and then wouldnt start. I let it sit for atleast 6 hours and went back to try to start it, and still wouldnt. It would just turn over. What can i do to fix it? I think it may not be getting fuel to the engine, but am not sure.
Old Dec 6, 2007 | 11:34 PM
yevgenievich's Avatar
yevgenievich
Default RE: Problem with gas getting to engine.
can you hear the fuel pump runing? Could be ecu going bad. There would be fuel line that you can unplug and crank to see if any fuel woud cme out. Actually just turning key in on position should start the fuel pump
Old Dec 7, 2007 | 06:25 AM
Danny~G's Avatar
Danny~G
the pile of snow could have bent a fuel line[sm=bounceybounce.gif]
Old Dec 10, 2007 | 10:32 PM
secretsTeaLtHeS's Avatar
secretsTeaLtHeS
happen to me too last year , u probably bent the fuel line
Old Jan 9, 2008 | 03:25 PM
cruisingthesouth's Avatar
cruisingthesouth
Did you ever get the problem fixed?
