Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
First time stealth owner needs help
Old Dec 4, 2004 | 07:37 AM
thevirus's Avatar
thevirus
Default First time stealth owner needs help
I'm 16 and i just bought a my first car. its a 1992 base model stealth.
I want to begin modifying with parts that i can afford on the small budget that i have. I'm looking for some performance gains so i was wondering what the best route to take would be? This is all pretty new to me so any suggestions or comments would help. Thanks
Old Dec 4, 2004 | 11:47 PM
thestealth's Avatar
thestealth
Default RE: First time stealth owner needs help
NA upgrade bible from 3si.com
Browse through this upgrade bible. It will give you a good idea on what you can do.
Also Rippmods.com is almost done developing a SDS (supercharger) kit for our cars. Reputed to give a bump of 80 to 100 HP (not cheap though)
Do you have a DOHC or a SOHC motor in your car. If you have a SOHC Ripp already has a SDS kit for them. Good luck, but I will warn you that not many upgrades are "cheap"
Old Dec 5, 2004 | 04:55 AM
thevirus's Avatar
thevirus
thanks a lot man. the link is very helpful. and yes my car is SOHC
Old Jan 13, 2005 | 07:33 PM
sweetbluDMC's Avatar
sweetbluDMC
if you really want alot of info on your stealth. and I mean anything and everything you could ever want to know. go to www.3si.org I own a 94 stealth base modelthat is modded to the max. I own every bolt on mod made for our cars and even a few that I modified to work on our cars. I learned alot from that msg board.
Craig
Old Jan 13, 2005 | 07:42 PM
sweetbluDMC
as far as the best route to take.. if you are completely stock. start with an intake and exhaust.. and don't waste your money buying a pre made performance exhaust, go to your local exhaust shop and have them make you a cat back, then get a test pipe to replace your catalytic converter, then go to www.3sx performance.com and get a performance down pipe, then go to www.3kgtmotorsports.com and get you a set of headders.. between those 3 sites you should be pretty much set for anything you could possibly want to do to your car. and just for good measure here's another. www.dnperformance.com
Craig
