Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
No fuel from injectors
Old Jan 6, 2008 | 11:34 PM
mt_sharon_mt's Avatar
mt_sharon_mt
Default No fuel from injectors
Just a quick question. On a 1993 Dodge Stealth SOHC3.0 whattells the injectors how much gas to put out. We have finally narrowed it down to the injectors not spraying.I have been having problems with this car for over a year. Does anyone out there have an answer for me? Is there some sort of relay anywhere? It is so hard to find a manual on this without having to pay a fortune. Any help would be greatly appreciated.
Old Jan 7, 2008 | 12:40 AM
cruisingthesouth's Avatar
cruisingthesouth
Default RE: No fuel from injectors
Is your fuel pump working?
Old Jan 7, 2008 | 01:44 AM
mt_sharon_mt
Yes. We replaced the fuel pump andthe fuel regulator. Well,I should say the garage did. We took it took them twice and it costs me like $600 and it still did not fix the problem. I should have said above that it starts intermittently. If it feels like starting it does. When it does start it runs perfect. Not a miss or anything.It has a lot of people baffled around here. We had it put on a diagnostic computerand he said everything was fine..nothing was showing up.
Old Jan 7, 2008 | 09:59 AM
cruisingthesouth
Have you tried the ECU. I believe that controls the spark and fuel injectors. I know the wiring harness that hooks into them runs to the engine computer.
Old Jan 7, 2008 | 10:03 AM
cruisingthesouth
Also you should go to automotiveforum.com and list your problem under there. There are acouple guys there thatknow pretty much anything aboutthesecars
