Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Engine Light!
Old Jan 14, 2008 | 12:14 AM
tokex420's Avatar
tokex420
Default Engine Light!
My engine light came on for 10-20 seconds 3 times, usually when I just worm up the car and start to drive and only once untill the next time I strat to drive after a while.4 possiblities, can it have to do with a blow off valve I put on, can it be that I got rear ended not to hard but dented trunk and hole in bumper, and it started to happen that day, I had very low oil, or just some other problem?
Any advise would be great thank you
Old Jan 14, 2008 | 11:24 AM
yevgenievich's Avatar
yevgenievich
Default RE: Engine Light!
you can check for codes with a voltmeter. search the forum it's been posted how to check before
Old Jan 14, 2008 | 12:17 PM
thestealth's Avatar
thestealth
If your car is a 95 or older, you should be able to check the codes via this procedure.
http://www.stealth316.com/2-diagcodes91-93.htm
Old Jan 15, 2008 | 01:36 AM
tokex420's Avatar
tokex420
thx ill check it out
Old Jan 25, 2008 | 06:06 AM
hsimpson's Avatar
hsimpson
ty for all the info I have learned a lot from everyone here
Old Jan 25, 2008 | 09:54 AM
thestealth's Avatar
thestealth
You're welcome.
