Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Clutch or Tranny problem?
Old Jan 18, 2008 | 08:59 AM
JSouthTwinTurbo's Avatar
JSouthTwinTurbo
Default Clutch or Tranny problem?
I have a 94 R/T TT 6 speed and the reverse is gone, it acts like is is but let off the pedal and it pops out or grinds. Also when in all the other gears it reves up but takes a second for the car to respond. Any ideas? Need some guidence.
Old Jan 18, 2008 | 06:19 PM
yevgenievich's Avatar
yevgenievich
Default RE: Clutch or Tranny problem?
reving up but taking a second t respond suds like cutch, the reverse being gone seems to be more transmission related. Coult still be a linkage tho
Old Mar 4, 2008 | 09:39 AM
theharley's Avatar
theharley
I have a '91 stealth ES 5 speed and it has the same problem with reverse and first gear, they pop out/grind when I try to shift into them. Sometimes I can get it to go into gear after a few tries.
I took it to a mechanic and he said the master cylinder in the tranny is going out. I have a new clutch that I got in november. So it's probably that OR it's a problem with the syncronizers. Do you have the standard transmission fluid or one for performance? If standard... that causes problems with gears and grinding for the syncros. This car has been known for transmission problems, sadly.
