Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
what is going wrong?????!!!!!!!
Old Mar 11, 2008 | 08:23 PM
michap62's Avatar
michap62
Default what is going wrong?????!!!!!!!
ok i have a 1992 dodge stealth es ( stickshift ) ..... and i am having a problem with it and that is, is that when i have it gear ( any gear ) and i give it gas the engine rev's but the car doesn't move! and just a couple days ago i had a mechanic install a new master cylinder in the car! so i don't know if that has to do with anything! .... bit i do know that its not a clutch problem because it has a new clutch less then a year ago! ... so does anyone have any suggestions what i should do? or what is wrong with the car?
Old Mar 11, 2008 | 08:42 PM
thestealth's Avatar
thestealth
Default RE: what is going wrong?????!!!!!!!
Do you happen to have a broken cv joint? You very possibly could have a bad clutch...
