Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Idle speed
Old May 21, 2008 | 06:05 PM
44stealth's Avatar
44stealth
Default Idle speed
93 R/T 5 spd
I just changed my computer since it went bad. they could not even rebuild it. Just to make sure I checked the ISC and it has a short. Honestly I never felt anything , when driving and probably I drove like that for at least 8 months to a year . With a/c rpm did not go up but actually did not slow down either. Got a new at rockautoparts good price about $75. When I put it in RPM went up and when switching on a/c it went even higher. Now I can cruise 40 miles/hour without tuching the pedal. So make it short somehow my rpm comes down but it takes a long time: 1 red light. Than we go again. I put back the old one with the short and idle is normal except it does not go up nor down whatever I do. I' m afraid to kill my computer by runnig around with a bad ISC. I compared the the new with the old and the new has a somewhat shorter rod the parth which goes itnto the throttle body.
The part# AC99 just for anybody if you have a problem? ALso this ohm is reading 41 and the old ones are 32 but they say it does not count.
Is there anyway to use the old one without damaging the computer?
Could it be that the new part even though it supposed to be good it isn't
Thanks
Old May 21, 2008 | 07:32 PM
44stealth's Avatar
44stealth
Default RE: Idle speed
Just to add a question
I tried running with the Isc disconected and it just runs fine at a steady idle Would that harm the computer? I m hoping since it is not connected I should be fine , I do not get any check engine light nothing Anybody tried this before???????[/align]
Old May 26, 2008 | 04:38 PM
yevgenievich's Avatar
yevgenievich
just unpluging it doesn't solve the problem but should not damage your computer. I have it unpluged on my firebird to get better idle with no problems untill i get enough cash to get a new motor
Old May 29, 2008 | 10:39 PM
sneakystealth92's Avatar
sneakystealth92
wats the typical idle rpm for a 92 sohc?
Old May 30, 2008 | 01:50 AM
yevgenievich
at initial start up mine idles almost at 2k rpm then drops down to 700 or 800 rpm
Old May 30, 2008 | 03:00 PM
sneakystealth92
mine starts off at 1k and goes down to like 500-600
