Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
ECU went out on 91 stealth
Old Jun 24, 2008 | 05:29 PM
kickflipninja's Avatar
kickflipninja
Junior Member
Default ECU went out on 91 stealth
the ECU went out on my car so now its not pumping gas when its suposed to so it barly stays started and its really stupid does anyone know the cheepest way to fix this problem is possibly without buying a new ECU because i can't afford one thanks.
Old Jun 25, 2008 | 03:14 PM
yevgenievich's Avatar
yevgenievich
Default RE: ECU went out on 91 stealth
check for leaking capacitors. If that is the problem you can send it to http://www.ecmtogo.com/.
Are you sure it's not your fuel pump or injectors?
