Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
HELP! engine bogging and studdering
Old Jan 5, 2009 | 01:39 AM
amaitland289's Avatar
amaitland289
Default HELP! engine bogging and studdering
i have a 95 stealth and when its in low rpms the engine bogs and studders and sounds like its not getting enough fuel. when im on the highway it drives pretty normal. but when i stop or climb a hill it studders an sounds like it wants to stall. the lights dim an you can feel the car bump like somthings misfireing or somthing while it idles. i was thinking it was fuel or air related but im becomming very frustrated haha. anyone have any ideas?!?
Old Jan 5, 2009 | 09:55 PM
cheetoz49r's Avatar
cheetoz49r
Default check the alternator
you might have a bad alternator. or the belt is loose. when your at Idle the alternator probably not putting enough voltage then when you raise the rpm the voltage goes up.
Old Jan 6, 2009 | 11:19 AM
bad venge's Avatar
bad venge
Section Moderator
When was the last time you replaced the fuel filter ???
A partially clogged filter may be too restricted at idle with more throttle enough fuel gets thru
Old Jan 6, 2009 | 12:31 PM
Dizzy772's Avatar
Dizzy772
It may be your bleeder valve on your throttle body. Pull that little rubber stopper off and loosen the bolt.
Old Jan 31, 2009 | 08:49 PM
GSRider's Avatar
GSRider
Still having the problem? Check your EGR valve. prolly cluttered with carbon deposits.
