Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
92 stealth dohc 6g72 engine swap with 93 3000gt
Old Jan 31, 2009 | 06:09 PM
sickstealth1's Avatar
sickstealth1
Question 92 stealth dohc 6g72 engine swap with 93 3000gt
i have a 92 dodge stealth and im putting a 93 3000gt engine in it, i notice that the 3000gt engine doesnt have a cam sensor near the throttle body like my stealth engine,but it has the 2 sensor on the pully side of the engine .how do i make this swap work?put the cam sensor from the stealth engine into the 3000gt engine and hook up the sensors or do i wire them direct and not transfer the cam sensor? also do they use different ecu computers? someone told me the heads might be different but being the same engine 6g72 idk if thats true??any help would be great
Old Feb 27, 2009 | 02:04 AM
yevgenievich's Avatar
yevgenievich
if you are using harness from the stealth then use the sensors that came with the stealth motor. I'm guessing 3000gt motor is a newer 94+ motor which is why there are differences. If you can get the ecu and harness from the 3000gt then just use those
