Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
91 Dohc Stealth to A 93 Shoc motor
Old May 21, 2009 | 11:06 AM
timmarkyager's Avatar
timmarkyager
Default 91 Dohc Stealth to A 93 Shoc motor
i have a 91 dodge stealth 5 speed dohc with a knock in the motor i paid 400 for the car no tyranny and few very little body parts car only has 77k on miles very clean but i just picked up a shoc and 5 speed off crealsit for $250 only 88k on motor trans but i wondering what all has to be changed to do this i know wiring and **** but it cant be that bad right 91 to 93 same its not a probale doing it for me its just the know be for i get in to it so if you know so ideas plese Thanks Tim
Old May 21, 2009 | 06:43 PM
alan92rttt's Avatar
alan92rttt
You do realize that the SOHC engine has about 50 hp less than the DOHC engine?
Old May 22, 2009 | 08:52 AM
timmarkyager
yes i have a 94 stealth with one but the 91 dohc has a knock in motor what im told but all power and no metal in the oil probaly spun bareing or piston rig but for only 77k on it idk so its eather bolt up the five speed see and hear the motor or just put the shoc and the 5 speed and in all honstly i heard the dohc is under rated and my 94 with all my perfomance parts on it is very colse to the dohc and the shoc is more relibale and runs for ever my 94 150k on the shoc only main seal rear and some gasket changed and im rebulding the auto for it this week and some of next its clean for 150k it dose not realy need a rebild i was scared just hearing how bad the autos are thought
Old Jun 19, 2009 | 01:13 PM
93stealthes's Avatar
93stealthes
i have a 93 stealth es dohc an ive never had a problem wit it until now an all tht it is, is it wont start when its hot so im doin a tune up on it. an hopefully tht will fix it, but i run the ***** off mine an its good to me, its only got 86k on it an i havent had a problem with the motor at all. but if it was me id rather have a dohc than a soch. but most of all the tt.
Old Jun 22, 2009 | 03:46 AM
SPARTANENGINEER1701's Avatar
SPARTANENGINEER1701
sohc have alot lower comp ratio 8.9 -1
dohc 10-1
sohc needs the new valve guides
but wit lower comp the engine lives under a teen tuner foot
PUT A NEW OIL PUMP ON AND WATERPUMP AND TIMING BELT
