Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
92 Stealth, AWD, Trans wont come off, HELP
Old May 21, 2009 | 06:47 PM
standbackimapro's Avatar
standbackimapro
Default 92 Stealth, AWD, Trans wont come off, HELP
Me and my friends are doing a clutch on a 92 stealth AWD, Twin turbo...
All the trans bolts are out, rear drive shaft, axles, the bar that runs under the trans, the 2 bolts holding that rear bracket near the rear engine mount are also off, all the plugs are off, the slave cylinder is off.. the trans is loose and about a half inch away from the engine block..
But we cannot get the trans off, its not hitting on anything on the outside, it seems like its stuck on the shaft, ive tried jacking up the trans, and the engine, and still nothing
If i look in the vent holes on the trans bell housing, i can see the pressure plate and it looks like the springs are bent in kinda like a hook
Old May 26, 2009 | 04:07 PM
alan92rttt's Avatar
alan92rttt
transfer case?
shift cables?
