Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Driver side door window pulley cable broken
Old Apr 10, 2010 | 04:59 PM
mmcgibbony's Avatar
mmcgibbony
Default Driver side door window pulley cable broken
Hey Gents,
I have a 93 Dodge Stealth that I have pulled the driver side door panel to access the regulator and motor to replace. However, when I peeled everything back, I see that the cable that goes around the pulley at the top of the door chasis has broken. How do I get that system out of the inside of the door to replace the cable? Any ideas?
Thanks,
MPM
Old Apr 22, 2010 | 10:09 PM
thestealth's Avatar
thestealth
You can't replace just the cable, you have to buy the whole regulator assembly. You can roll your dice with a used one or rebuilt one or buy one from a dealer. It's about 250 bucks new.
Offhand, I believe there are 3 or 4 bolts holding the motor/lower portion to the door and 2 that hold the glass.
