Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
1994 Dodge stealth i need HELP please?
Old Jan 12, 2011 | 05:00 PM
josh4345's Avatar
josh4345
Exclamation 1994 Dodge stealth i need HELP please?
ok so heres the deal, i completely rebuilt the motor on my stealth DOHC non turbo and it ran perfectly untill i washed it then it died so i let it sit then it started right up. i got 20 miles and it died, let it sit, started right up, then after 60 miles it wont start at all. well its NOT getting spark on 4 cylinders, only getting spark on 1 coil pack. i tested the others and they are fine. so i replaced the crank sensor and the ICM and the harness and i took apart the ECM and no leakage on the capasitors. when i tested the crank sensor even after the autozone one was put on i have 5 volts coming out and nothing coming out of the ECM on those 2 coil packs. if ANYONE could help i would greatly appreciate it!!!!!
